Home » Audio » Speaker » Pro line arrays
Re: Pro line arrays [message #24029 is a reply to message #24028] Wed, 14 November 2007 08:33 Go to previous messageGo to previous message
Crystal is currently offline  Crystal
Thank you for that advice. The ART arrays are off the table for live sound. That would probably be the same for Straight 8 then too, with its 8 driver array and its single dome tweeter. Or is it different because they changed out the dome tweeter for a slot loaded compression tweeter? They are using the Straight 8 as a live sound speaker.
What do you think?
Crystal
Previous Topic: Mystery Crossover
Next Topic: Vintage 15" woofer recommendation for OB midbass array?
Current Time: Wed Sep 09 18:18:50 CDT 2026
