Home » Audio » Speaker » Pro line arrays
Re: Pro line arrays [message #24026 is a reply to message #24025] Tue, 13 November 2007 11:58 Go to previous messageGo to previous message
Anonymous
You can use any good line array design for live sound as long
as you don't abuse the speaker and blow up drivers. heh
One guy I talked to in private made a cheap stackable line
array using 49 cent buyout 4" midranges and he thinks it's
great for his band when they do small gigs.
The proaudio designs are modular;
http://home.earthlink.net/~ralaudio/i/vant/d.jpg
Stack as many as you need, easy install/tear-down.
You can implement this type of stackable design in your house
if you wanted to. Dali Megaline is a stackable home line array but their modules are larger in size.
For high output concert sound where there is potential for
driver abuse, the common tweeters you see used in the home line
array designs {commercial or DIY} may not be robust enough
or offer the lowest distortion compared to the better planar
tweeters found in certain proaudio arrays.
Previous Topic: Mystery Crossover
Next Topic: Vintage 15" woofer recommendation for OB midbass array?
Current Time: Wed Sep 09 18:19:00 CDT 2026
