Home » Audio » Speaker » Open back array
Re: Open back array [message #24010 is a reply to message #24009] Mon, 05 November 2007 23:14 Go to previous messageGo to previous message
tolits is currently offline  tolits
If you look at the shape of the side view of the cone, it looks like at triangle. On the negative going signal, it moves like a spear. On the other hand on the positive going signal, it has a higher drag because of the parachute effect of the cone. What I do is use a tube configured in such a way I can variably decrease the negative going signal .
Regarding my impression with the two 6.5 driver with Neo8 at middle It takes the performance to a higher level than the focals but with the negative limiting signal in place.Distortion became lower,imaging became better, Naturalness also has been enhanced. I would not go back to the Focal arrays in a close back and the 8 Neo.To me,It is simply a different level considering the bassmid are very cheap.
Previous Topic: Vintage 15" woofer recommendation for OB midbass array?
Next Topic: The Zigmahornets
Current Time: Wed Oct 21 12:13:24 CDT 2026
