Home » Audio » Speaker » The "Tallerays"
Re: The "Tallerays" [message #23949 is a reply to message #23948] Fri, 07 September 2007 04:05 Go to previous messageGo to previous message
I'm still surprised that the Foster drivers sound as good as they do connected direct to the amp with no filtering at all. They don't have the midrange clarity of better drivers like the Dayton Reference series, but they don't do anything that would be distracting, like a breakup spike at 5 to 7khz. I have no idea why this is so, because I saw a PDF of their response and it showed a fairly pronounced spike at these frequencies.
The waveguide is the 7" elliptical from Parts Express, #270-316. I used fourteen drivers for the worst possible reason; I wanted people to gasp in astonishment (WOW!!!) when they first saw it. I succeeded, but nine, ten or twelve would be a more practical choice, both in terms of a more manageable size and the fact that 7'4" is too tall for the typical listening room where your listening chair is less than 10' from the speakers. If you wanted the woofer array to be arranged symmetrically above and below the tweeter you would have to use ten (3-3-4, with the four consisting of the top two and the bottom two woofers, giving you 8.7 ohms nominal impedance) or twelve (3-3-3-3 or 4-4-4), yielding a nominal impedance of 6 ohms or 10.7 ohms.
Previous Topic: Which amp Should i get
Next Topic: Sick of my wonky wires
Current Time: Fri Nov 06 00:52:34 CST 2026
