Home » Audio » Speaker » If you ...
Re: Lets try this again....... [message #23943 is a reply to message #23941] Wed, 05 September 2007 21:28 Go to previous messageGo to previous message
Rick Craig is currently offline  Rick Craig
The issue with adding a second line of 3.5" drivers to your design is that the tweeter won't cross low enough. Even with a single line of 3.5" drivers a dome that small is not a good idea and it can easily be proven with good measurements. Why do you think Jim Griffin has only used planars or ribbons in his arrays?
Not all of the McIntosh arrays use the same spacing and driver sizes; however, keep in mind that some of the small drivers they use can be crossed lower than what you use because of the way the drivers are designed.
Previous Topic: Replacing Monsoon MM:1000 speakers
Next Topic: Basshorn article in AudioXpress
Current Time: Sat Nov 23 05:19:48 CST 2024
