Home » Audio » Speaker » If you ...
Re: More questions? [message #23937 is a reply to message #23936] Wed, 05 September 2007 05:16 Go to previous messageGo to previous message
Marlboro
Re: "The extra line of woofers will provide identical coverage in the horizontal plane to the left or right. With a single line of woofers this isn't possible though you can correct for it with a DSP crossover like the DEQX or TacT."
OK(if I may step in here).... But what is the hearing difference and what is it that you are correcting for that you can hear a change for? Since I have a line of 16 3.5 inch woofers connected to a line of 3/4 inch dome tweeters with flanges cut to a c-to-c of about .9 inch, what difference would I hear by adding anther line of 3.5 inchers on the other side of the tweeters? I'd also have to be careful of the distance between the woofers causing potential horizontal comb filter issues.
Previous Topic: Replacing Monsoon MM:1000 speakers
Next Topic: Basshorn article in AudioXpress
Current Time: Fri Sep 27 14:01:46 CDT 2024
