Home » Audio » Speaker » If you ...
Re: one idea [message #23934 is a reply to message #23933] Tue, 04 September 2007 14:37 Go to previous messageGo to previous message
Rick Craig is currently offline  Rick Craig
Adding more drivers changes the crossover and can also change the wiring configuration. With that in mind I wouldn't go that route but if you're running active it certainly would be easy to do. I'm also not sure how much of a negative effect the gaps in the lines would be.
Previous Topic: Replacing Monsoon MM:1000 speakers
Next Topic: Basshorn article in AudioXpress
Current Time: Fri Sep 27 14:10:55 CDT 2024
