Home » Audio » Speaker » passive crossover point
Re: passive crossover point [message #23896 is a reply to message #23895] Mon, 23 July 2007 12:15 Go to previous messageGo to previous message
zobsky is currently offline  zobsky
Thanks for all the help, Wayne.
Last week, I used foobar 2000's DSP filter plugin to test various filter types / x-over points and slopes . There didn't seem to be much difference (if any) between a 4KHz and 5 KHz point, so I picked 5KHz as the higher x-over point allows the tweeters to play louder with less distortion.
I've ordered parts for a 5KHz / 3rd order filter and a zobel ciruit for the open baffle woofer array . Rather than use a passive filter to tame the mid-bass / mid-range hump, I plan to use the eq. in foobar 2000 for this purpose, if I eventually find it an issue. The tweeter impedance peak is fairly benign (2 ohm above the nominal 6 ohms).
Almost there.
Previous Topic: Conical HF Horn?
Next Topic: Solid wood Pawos
Current Time: Fri Oct 16 20:56:13 CDT 2026
