Home » Audio » Speaker » DCX crossover installed
Re: Can tone be fixed with eq? [message #23857 is a reply to message #23855] Mon, 09 July 2007 09:32 Go to previous messageGo to previous message
jphaggar is currently offline  jphaggar
I've applied 6db baffle step to the input at 250Hz upwards on a 6db slope and got some improvement but still not what I want the sound to be !! I think the cone material is probably the most important issue and I recommend to anyone going for a project as important as a line array to buy the best Mid/Bass drivers and I presume that treated paper cones should be the choice , but meanwhile could I rectify some of the cone problems using some EQ ? If yes what are the frequencies that are typical to this particular driver and that could be rectified if someone has tested this Dayton RS 180?
Previous Topic: JBL 2225H reconed as a 2235H?
Next Topic: JBL G-730 Diaphragm quest
Current Time: Sat Oct 31 16:46:50 CDT 2026
