Home » Audio » Speaker » DCX crossover installed
Re: DCX crossover installed [message #23845 is a reply to message #23844] Tue, 03 July 2007 09:48 Go to previous messageGo to previous message
lcholke is currently offline  lcholke
The cabs look great. You have almost the exact speaker that I have. The tweeters are the same. The box looks basically the same. I have the silver flute woofers. I ended placing some silicone on the dust caps to eliminate some of the resonance.
What are the settings on the behringer xover. Did you make a baffle step compensation? What are the xover points?
-Linc
Previous Topic: JBL 2225H reconed as a 2235H?
Next Topic: JBL G-730 Diaphragm quest
Current Time: Sat Oct 31 16:46:14 CDT 2026
