Home » Audio » Speaker » DCX crossover installed
Re: DCX crossover installed [message #23837 is a reply to message #23836] Wed, 27 June 2007 09:19 Go to previous messageGo to previous message
Marlboro
Well, obviously I disagree that you can build a conventional system with the same sound presence, low distortion, and dynamic range as you can for a line array.
Some line array designs are better than others. I personally believe that my own design is head an shoulders above many others including the commercial ones.
I have an equalizer, but I don't use it. Both my tweeter and woofer array amps have individual volume controls which allows me to modify the system without resorting to phase whacking equalization.
Sorry your system doesn't meet your needs.
Marlboro
Previous Topic: JBL 2225H reconed as a 2235H?
Next Topic: JBL G-730 Diaphragm quest
Current Time: Sat Oct 31 16:47:04 CDT 2026
