Home » Audio » Speaker » Array Tweeter Selection
Re: Array Tweeter Selection [message #23786 is a reply to message #23781] Fri, 01 June 2007 09:37 Go to previous messageGo to previous message
Anonymous
re: Zaph's tests.
People make decisions based on tests, people should buy sample
drivers and do their own listening tests as it offers peace of mind.
Keep in mind that Zaph tested the Silver Flute Yag-20 which is
similar to the PT2B, but as Rick said the PT2B has a better magnet
as is evident by the different in sensitivity ratings. Yag-20 is
rated at 90dB, PT2B is 94dB. It would be premature to rule out PT2B
if you look at Yag-20 tests. Zaph also makes a note about drivers used in line arrays.
For a non-line array design I would choose a dome tweeter instead
of PT2B. But for a big line array with eight - tweleve PT2B per tower, that's hard to beat for the money. You can go to home audio
stores and not find that sound for $20k.
You should be able to get those tweeters for $25 in bulk pricing
and for the money, they do a good job. If you use 48dB/octave active
crossover {DCX2496, etal}, you can stretch the crossover frequency lower. You can also keep more distortion from manifesting when you
push the line array to higher levels. You can also change the crossover frequency for different listening situations. The active
crossover has advantages where passive crossovers are fixed.
re: BG Neo3
There is also BG Neo3PDR, an upgrade to BG Neo3.
Sensitivity is lower; 90dB/2.83v, 4 ohm
re: Esoteric solutions
I didn't mention it before, but I can think of more tweeters to
add in this category, but you'd be spending $700 - $2000 on each
tweeter. lol Is it worth it? Sure it is if you want to push the
SPL level higher and keep distortion lower. I'm going to guess
and say you can probably generate at least 120dB[c] of treble at
12-20 feet away with these expensive tweeters. The highest end
tweeter is rated for 145dB, 3kw peak power, 200mS. lol ...
Based on what I've seen, it seems the logical progression would
be; $1 mylar, $4 dome, $25 PT2B, $120 Fountek {or equivalent that
may cost $200}, then the $300 - $500 ribbons. Just figure out what
your budget is and find the tweeter that fits the wallet.
If you can't choose, buy one of each driver candidate and hook it
up and just listen to the sound.
Previous Topic: 2 or 3 way line array
Next Topic: DCA4 damage
Current Time: Sun Nov 29 04:15:45 CST 2026
