Home » Audio » Speaker » musical peaks / SPL / power distribution
Re: musical peaks / SPL / power distribution [message #23603 is a reply to message #23601] Mon, 02 April 2007 21:00 Go to previous messageGo to previous message
Marlboro
Have you read Jim Griffin's line array paper?
How loud it can play really doesn't make any difference. By the numbers, my dual 12 inch woofer, 34 3.5 inch midranges, 60 dome tweeters running tri amped with 1300 watts can pump out 141 db.
But the key is not how loud, but its how incredibly detailed and almost intimate astounding the experience can be. With small groups its the closest thing to having these people actually in your listeing room playing just for you.... Most of the time I play it and can talk while listening.
I know this isn't the answer you wanted...
Marlboro
Previous Topic: ribbon protection with electronic crossover?
Next Topic: Fullrange line array?????
Current Time: Fri Nov 06 05:13:15 CST 2026
