Home » Audio » Speaker » Tell Us About the Array you built or are building......
Re: Tell Us About the Array you built or are building...... [message #23596 is a reply to message #23594] Sun, 01 April 2007 08:35 Go to previous messageGo to previous message
Marlboro
If you put only six of these woofers in a 72 inch line array, they are going to be 12 center to center inches apart. This means that to avoid serious and very audible comb filter distortion, you will need to cross to your tweeters at about 1130hz.
I couldn't find any specs on them but i guess its within the realm of possibility that they do go down that low since the B&G ribbon lines go to 600hz.
How much is the total cost for this monster?
Marlboro
Previous Topic: Even more on slam - and imaging!
Next Topic: Relationship Between X Max And Efficiency Questions
Current Time: Thu Nov 05 22:40:38 CST 2026
