Home » Audio » Speaker » Use of multi-meter for measure impedance of lines Question..
Re: direct answer to Wayne [message #23581 is a reply to message #23580] Wed, 21 March 2007 11:54 Go to previous messageGo to previous message
I see, or at least I think I do. You're saying you want to double-check your wiring, right? If so, I'm not sure I can recommend a short-cut. You can measure total impedance for a "sanity check" - If it's way off then you'll know something is wrong. For example, one would expect a series/parallel network of four 8Ω drivers to measure 8Ω total, so if it didn't you would know something is amiss. But there is no substitution for checking point-to-point connections. Even if you measure impedance and find it's right, you won't know that polarity is right for each driver without a response chart. Best to check your wiring, point-to-point.
Previous Topic: possible blown woofer? help?
Next Topic: Cogent True to Life/Welborne Labs
Current Time: Wed Sep 23 11:05:08 CDT 2026
