Home » Audio » Speaker » another ART array question....
Re: another ART array question.... [message #23576 is a reply to message #23568] Tue, 20 March 2007 04:02 Go to previous messageGo to previous message
The quick disconnects are designed to be attached to the wires using a crimping too. Another option would be to solder the wires directly to the speaker terminals, but I prefer to use the quick disconnects at least until I'm certain I will not be pulling the speakers.
If you want to upgrade the internal wiring, 12 ga Belden 5000UE cable is available from Blue Jeans cable for 38 cents/ft. It's a neutral sounding high purity copper. You will have to strip off the outer cover, but there's a "zip cord" inside that makes it very easy.
Previous Topic: No power from my Wharfdale Active Pro 8.2 speaker
Next Topic: possible blown woofer? help?
Current Time: Sun Nov 01 04:31:09 CST 2026
