Home » Audio » Speaker » Anybody want to build a DIY IDS-25 clone (somewhat cheaply)?
Replies for all that have replied so far... [message #23548 is a reply to message #23534] Tue, 13 March 2007 20:53 Go to previous messageGo to previous message
Aaron D is currently offline  Aaron D
Thanks for the input. I appreciate the discussion (honestly I do) but this is mostly rehashed stuff form other threads in this forum. I kind of tried to avoid this w/ the "DISCLIAMER" from the original post. Admittedly I left a few details out of the disclaimer but the point of the post was found in the topic (I am looking for someone to split 100 drivers with). My point was not to defend this project.
In no certain order:
I am planning on using a sub. In fact I am working on 2 18's that will be powered by a 500 watt Hafler amp. I think I have that covered.
EQ: I am planning on getting a DEQ2496. I have had one on my wish list for quite some time and would like to get one for use the RS8 array eventually. It seems that most agree the 2496 is adequate for this job too.
Lack of bass/highs. Bass is covered. When you buiild an aray for $300 in drivers you will sacrifice something, particularly in off axis response.
Different divers: I picked these Aura's based partly on price but also because they will do the job. I am sure there are better options but they will more likely improve the low end (which I do not really need) more so than the high end. The low end will (assuming) come at the cost of a larger enclosure and a fair amount more cash.
Adding a tweeter: I have considered it as a future option. If I do so I will simply mount it to the side of the existing array as close a possible to the line. I do have a pair of Fountek 3.0's that I got a good deal on that would work great. Definitely worth considering but that is another project for another day...
I want to build a set of nice speakers that will sound great for the small amount of $$ spent.
Now, does anyone want to go in half on 100 Aura drivers?
Thanks,
Aaron
Previous Topic: Back from Dallas and depressed ...
Next Topic: ART Array construction continues.... and a question
Current Time: Sun Oct 25 03:22:33 CDT 2026
