Home » Audio » Speaker » Rane, Behringer and the 400 5.6
Re: Rane, Behringer and the 400 5.6 [message #23507 is a reply to message #23495] Sun, 04 March 2007 03:07 Go to previous messageGo to previous message
SnakeFingers is currently offline  SnakeFingers
Actually, good advice as far as it goes.
There's some truth and wisdom in this advice, but it leaves out a critical test: side by side, A-B comparisons. Even when two devices share the same IC's, the support circuitry can be different enough to make an audible difference.
Take a friend to the store with you, let him or her run the test, you keep back far enough so you can't see which unit you're listening to. Keep everything else the same for each listen, the only thing that should change is the device you're auditioning.
This will tell you which one sounds better. If it's a wash, then it doesn't matter which brand you use. If you can hear a difference, go with the one that sounds best to you. Sometimes it may the less expensive unit. Go with your ears, but you gotta listen and compare.
Previous Topic: What's Vintage Sound?
Next Topic: anyone tried equidistant spacing?
Current Time: Mon Sep 21 21:44:16 CDT 2026
