Home » Audio » Speaker » Small array for a small listening room. Help and advice needed.
You are not building an array..... [message #23447 is a reply to message #23445] Thu, 15 February 2007 06:10 Go to previous messageGo to previous message
Marlboro
This is not a Line Array Speaker system. You are building a point source speaker. I recommend that you download Jim Griffin's white paper, or I'll send you a copy.
To have an array, the system has to be coupled with the floor and the ceiling, and you have to be in the nearfield for listening. The nearfield is roughly 3 times the array size, which means that you would have to listen to the system less than 4 feet from the speakers, and the size doesn't couple with the floor and the ceiling. And even at this distance you would not be in the nearfield for the tweeter. So you are just building a large point source speaker system. I suggest you consider a D'Appolito MTM design with a couple of larger woofers at the bottom.
There is no such thing as a small array. You either have a line array or you don't.
Marlboro
Previous Topic: Selah Audio XT-8 Review
Next Topic: ART array question
Current Time: Fri Oct 23 08:26:48 CDT 2026
