Home » Audio » Speaker » Newform R30 / Scan 8545 array
Re: Newform R30 / Scan 8545 array [message #23435 is a reply to message #23431] Thu, 08 February 2007 11:02 Go to previous messageGo to previous message
Are you running a balanced signal out from the x-over to a balanced input on the amplifier, this will help because the CMRR of the differential input will cancel out any noise. Go to Rane's website look under the white papers section, it also will tell you how to go from a balanced output to single ended input if your running that way.
Previous Topic: Art arrays are done
Next Topic: Ciare TW 1.8 horn tweeter from US Speaker?
Current Time: Fri Oct 23 09:26:28 CDT 2026
