Home » Audio » Speaker » matching Subwoofer
Re: matching Subwoofer [message #23374 is a reply to message #23350] Sun, 14 January 2007 07:21 Go to previous message
I have a line array per side of 17 3 inch wide ranges, and 32 Dayton Neo tweeters. it goes great down to about 100hz but not much below that even with all those little mids.
I use two 12 inch Goldsound(not Goldwood) 12 inch xmax woofers. They are in a vented 12 inch x 7 feet 6 inch sonotube woofer. The foot print is small, and the difference between a vented design and a sealed design at those low levels is negligible in sound, but much deeper in the bass. They kick! The volume size of each woofer is over 9 cu feet. There is no substitute for volume in the box......NONE!
Marlboro
Previous Topic: O.B. line array on Audio Circle
Next Topic: ProAC 2.5 Clone Project
Current Time: Tue Nov 03 14:19:51 CST 2026
