Home » Audio » Speaker » Newform R30 Scanspeak 18W/8545 array project
Re: Newform R30 Scanspeak 18W/8545 array project [message #23341 is a reply to message #23340] Sat, 23 December 2006 21:58 Go to previous messageGo to previous message
Stephen Narayan is currently offline  Stephen Narayan
Thanks for responding...
Well initially amplifiers will be SS PS Audio Delta 100 stereo amps, 2x120W into 8 Ohm. I have 2 available so I could biamp them using my Behringer DCX2496, but I may eventually decide to build passive crossovers for them mounted on an external rear panel so I can just use one amp or possibly dual monoblocks, or a pair of Bryston Power Pac amps in the future. Not sure what the far future would hold for them but if I build them large enough the efficiency gain might lead me to use a valve amplifier. And then again there's also the possibility to go Class D or Tripath based amp down the road.
Looking more into the design I believe the proper way to go right now is to go full hog and get another set of ribbons to stack alongside the array.
Previous Topic: Please recommend a smooth 18" x 8" HF horn & driver...
Next Topic: Array Enclosure Plans ie Northcreek Designs
Current Time: Sat Oct 31 09:20:10 CDT 2026
