Home » Audio » Speaker » Do Magnepan act as Line array?
Re: What's the difference between them then? [message #23274 is a reply to message #23270] Sun, 29 October 2006 17:21 Go to previous messageGo to previous message
Tom R. is currently offline  Tom R.
Please tell, me if this is correct:
A line array is a series of individual drivers mounted vertically creating a Radiation patters that helps eliminate wall, floor and ceiling reflections by projecting an large vertical enhanced beam pattern
A line source is an elongated planer driver with a large radiating surface that radiates in a pattern different that a line array,
So due to different radiation pattern of the two designs are not well suited mated together. As in the combination of: a line array with eight vertical 5-1/4” mid bass drivers mated with a set of Maggies crossed at 2500 Hz.?
The reason for the question is I am working on a line array with 8 high qualities mid bass drivers per side, which I own. But my funding for the ribbon tweeters section is close to being depletes. I wanted to use the Fountek NEO CD2.0 at $ 120 each. I would have needed 12 of these units, but now I have to lower my budget, and was just looking on E-Bay and saw the Maggies, and thought what if?
Tom
Previous Topic: ELECTROSTATIC RESEARCH SPEAKERS
Next Topic: Altec 604C in an Onken Style box??
Current Time: Sun Sep 13 18:47:31 CDT 2026
