Home » Audio » Speaker » Ported Enclosure for line array
Re: Ported Enclosure for line array [message #23216 is a reply to message #23212] Tue, 03 October 2006 14:16 Go to previous messageGo to previous message
JP Haggar is currently offline  JP Haggar
Thanks
Parts of the enclosure emit more sound than the actual drivers , by using a sound level meter I could spot around 200hz 400hz until 1660hz vibrations on the sides and back.
I guess the MDF I'm using has a low density (700 kg / m3 )and needs to be stiffen or maybe I should use 1" instead of 3/4" for sides and back , I decided to brace with horizontal sheves with openings in them ,between each driver that way the four sides are attached ?
About the port I still have to make a final decision as to where to place it , I have the alternative to put it in lower front, lower back, or mid back , considering I only have 30cm clearance from the back to the wall could you advise on that? Port is 15cm diam. and 9.5cm long box is tunes to 39hz .
Previous Topic: Re: Question on calculating woofer box volume
Next Topic: Logitech z5500 speaker help
Current Time: Mon Oct 05 22:51:43 CDT 2026
