Home » Audio » Speaker » Array Bass
Re: Array Bass [message #23185 is a reply to message #23173] Wed, 13 September 2006 07:07 Go to previous messageGo to previous message
David Yost is currently offline  David Yost
Have you considered using radical low frequency EQ like Roger Russell does with his new line arrays? He uses columns of 25 3 1/2" TB type full rangers that he claims are flat to 25Hz in room, and I don't doubt him. While his system uses a dedicated EQ, you could probably use a McIntosh MQ-104 or MQ107...they show up on ebay once in awhile.
I like this approach, as sub integration problems, crossovers, extra amps, etc. are eliminated. Also, I think overall bass response is much smoother everywhere in the room because you are using 25 spread out "woofers" rather than just one or two.
Previous Topic: What happens to T/S for dual horn drivers?
Next Topic: B&C Drivers
Current Time: Tue Oct 06 08:27:16 CDT 2026
