Home » Audio » Speaker » Listening distance
rd series [message #23161 is a reply to message #23156] Wed, 06 September 2006 10:59 Go to previous message
lcholke is currently offline  lcholke
Hi Slinco,
I think the main advantage of the rd series is the low xover point. It is like having a full range driver. You could use a first order xover. I heard a pair and they are very good. One issue is the low effency.
If you realy like the low xover feature these will be a good choice. You may want to listen to ribbon drivers also before deciding. The xover point will be in th 2k range though.
My array gets very quiet when listening closer than 2 ft.
-Linc
Previous Topic: What are the most important T/S characterisitics in an array speaker?
Next Topic: Comparison to Nearfield Acoustics Pipedreams with our DIY?
Current Time: Fri Oct 16 21:04:32 CDT 2026
