Home » Audio » Speaker » Dipole for an array. Is it...?
Re: Dipole for an array. Is it...? [message #23096 is a reply to message #23091] Wed, 02 August 2006 21:32 Go to previous message
Rick Craig is currently offline  Rick Craig
The dipole array presents two significant problems. One is mechanical construction - making it wide enough to support the desired wavelength cutoff and stability (how to support all that weight on the front and keep the rear / sides open).
The second problem is power response and this for me is a significant issue. A typical monopole home audio line of 5-6 ft. will not maintain the nearfield effect much below 200-300hz. Adding dipole radiation reduces the low frequency power response even more. Maybe with a large amount of active equalization you can correct this? I think it's an area to be explored.
Previous Topic: Dynaudio / Max-Fidelity
Next Topic: TC Sounds Array components for DIY
Current Time: Thu Nov 05 13:55:49 CST 2026
