Home » Audio » Speaker » Xover and line array
Re: Perfect line array [message #23015 is a reply to message #23014] Wed, 31 May 2006 21:56 Go to previous messageGo to previous message
Rick Craig is currently offline  Rick Craig
Send me one to test and I'll let you know how accurate the numbers are
The PT2 is rated at 94db but because of the contouring needed you actually lose a couple of db's. The Fountek is a true 98db and will work with a much wider variety of woofers.
Previous Topic: Need help with room placement
Next Topic: Integrating full-range as wide-range
Current Time: Fri Oct 16 12:57:49 CDT 2026
