Home » Audio » Speaker » Full range drivers in line array?
Re: Full range drivers in line array? [message #22944 is a reply to message #22943] Fri, 17 February 2006 07:31 Go to previous messageGo to previous message
Jorge,
Yes, that is the way to go in this case--use a crossover to a tweeter or a line of tweeters. I've found that simple first order crossovers (single component) aren't sharp enough for most line array implementations so a third or fourth order usually works better. Furthermore, the crossover likely will need to be when the midrange line starts to lose sensitivity. This would likely be in the 2-3.5 kHz area. Measurements help to determine specific crossover points.
Jim
Previous Topic: Help Wanted
Next Topic: Time Alignment - Horn/Compression & Woofer
Current Time: Fri Oct 16 12:57:57 CDT 2026
