Home » Audio » Speaker » Full range drivers in line array?
Re: Full range drivers in line array? [message #22931 is a reply to message #22928] Sun, 22 January 2006 09:02 Go to previous messageGo to previous message
Not necessarily, just remember that with a full range driver/1way system there are diminishing returns in the high frequencies as you make the line longer, and if you go long enough you're pretty much forced into either adding HF drivers or using electronic compensation.
Previous Topic: Help Wanted
Next Topic: Time Alignment - Horn/Compression & Woofer
Current Time: Fri Oct 16 12:57:11 CDT 2026
