Home » Audio » Speaker » Advice please
Re: Advice please [message #22905 is a reply to message #22895] Thu, 05 January 2006 20:08 Go to previous messageGo to previous message
RKM is currently offline  RKM
Have you considered the relative SPLs of your woofers versus the ribbon? The 30Hz to 300 Hz range needs a lot of Xmax for the same spl. Your Gold Ribbons probably can pump out the spls if they are anything like the B&G planars.
What max spl are you shooting for?
(As an aside I don't know anything, good or bad, about trinaural--I use a phantom center).
Previous Topic: Ping Retsel: your open baffle speaker?
Next Topic: please advice: 8 drivers, 95dB, 6ohm+
Current Time: Sat Nov 28 18:44:38 CST 2026
