Home » Audio » Speaker » Advice please
Re: Advice please [message #22904 is a reply to message #22901] Thu, 05 January 2006 20:01 Go to previous messageGo to previous message
RKM is currently offline  RKM
Go for it!
My DIY ribbon is similiar: a DIY ribbon of 48 inches with four 7 inch PE ES-180 woofers next to it crossed at 825 Hz. Vertical woofer spacing is 11 inches, ctc. Works fine. I can't find any evidence of comb filter problems.
Overall this speaker compares very favourably to my Eminent Technology LFT-VI which is a full 6 foot line source (although its ribbon tweeter is less than the full height).
The strictest guideline is ctc should be less than one-half a wavelength at all frequencies that overlap. I'm using a 4th order Linkwitz-Riley crossover (active) to minimize overlap. What type of crossover are you planning on using?
Previous Topic: Ping Retsel: your open baffle speaker?
Next Topic: please advice: 8 drivers, 95dB, 6ohm+
Current Time: Sat Nov 28 18:44:36 CST 2026
