Home » Audio » Speaker » Porting of Line Array
Re: Porting of Line Array [message #22881 is a reply to message #22877] Tue, 06 December 2005 10:00 Go to previous messageGo to previous message
Anonymous
Rear ports are good. You can probably combine the drivers in groups
and make chambers for each group to make the port design more
friendly, ie.. I build my budget array with four chambers, four
drivers per chamber, a 6" diameter rear port per chamber, 1 3/8"
port length. Turns out, the wood thickness of that rear wall is
1 3/8" so the port length = wood thickness so all I did was cut a
6" hole in the back of the cabinet and used a small roundover bit on
the edges. Obviously, this design is tuned higher in frequency.
http://home.pacbell.net/lordpk/robarray/6.jpg
Previous Topic: EPI /TL / EQ compensation
Next Topic: Parts Express Eminence "Factory Buyouts"
Current Time: Fri Nov 27 06:42:15 CST 2026
