Home » Audio » Speaker » FredArray II Nearing Completion
Budget Line Array Kits [message #22812 is a reply to message #22811] Fri, 09 September 2005 13:45 Go to previous messageGo to previous message
I forgot to mention, if you're looking for a very inexpensive array the FredArray is just that, but if you're looking for a serious pair of arrays that will serve as your main speakers there are two budget line array kits out there that use higher quality drivers than I used in the FredArray. These were designed by Danny Ritchie and Rick Craig, both of whom have the background and test equipment to produce a first class product that will rival anything on the market, but at a much more attractive price than mainstream products. They are the RAW Acoustics RA8 and the Selah Audio Day Tek. Both use better woofers combined with much higher quality ribbon tweeters, and you get complete detailed enclosure plans and competently designed crossovers with either one. I have either built or auditioned line arrays by both designers and would recommend their products without hesitation. Either kit can be built for less than $1,000 including the enclosure materials.
http://www.rawacoustics.com/
http://www.selahaudio.com/id103.html
Previous Topic: Driver Size Thoughts
Next Topic: further efforts with a developing array....
Current Time: Sat Nov 07 13:34:26 CST 2026
