Home » Audio » Speaker » I need to locate a custom speaker builder/company or someone to just exchange a coil for me
Re: I need to locate a custom speaker builder/company or someone to just exchange a coil for me [message #22806 is a reply to message #22805] Mon, 05 September 2005 16:53 Go to previous messageGo to previous message
Are you going to remove the magnet and modify it, adding a shorting ring? Or are you planning to work on the voice coil?
If the former, you need a machine shop. If the latter, a place that does recones can do the work for you.
Previous Topic: I need to locate a custom speaker builder/company or someone to just exchange a coil for me
Next Topic: Coral beta 8's
Current Time: Fri Nov 13 07:15:38 CST 2026
