Home » Audio » Speaker » When tapering not needed
12 twt's with 48 inch length need tapering or not? [message #22794 is a reply to message #22792] Fri, 26 August 2005 13:28 Go to previous messageGo to previous message
skaloumbakas is currently offline  skaloumbakas
Hi,
From what I know, Genesis for example in their top speakers (G350 & G201, which incorporate 12 tweeters) do not use tapering for their tweeters. They use the 3/3/3/3 wiring configuration.
Question A. I suppose they are correct (or not?) As you say Jim - and I have read your white paper with great interest - tweeters do not need that much tapering as woofers and mids... is it correct?
________________________________________
I am using the G300, which uses 2 tweeters and one super tweeter per speaker. (also one at the back)
Question B. Would you recommend to take the plunge and go for the 12 tweeters (and 3 at the back), drilling the extra holes and ordering their ribbon tweeters and the x/o
or...
it is risky and not worth the cost and work?
Christos
Previous Topic: Ping "Ed"
Next Topic: lowther drivers in cabinets
Current Time: Sun Oct 04 06:15:44 CDT 2026
