Home » Audio » Speaker » Looking at adding a mid woofer array
Re: Looking at adding a mid woofer array [message #22768 is a reply to message #22767] Mon, 08 August 2005 15:02 Go to previous messageGo to previous message
Zene Gillette is currently offline  Zene Gillette
Should you have said in the first place what you have (3") my queery would have been much different. Yep, you need help to your sub. Try to make the speakers as complimentary as you can. Paper to paper, etc. and even the same mfg if possible (that never seems to happen). A seamless crossover point is a primary concern. There is tremendous power in the 100hz - 500hz range. You may need a greater cone area than you indicate, but 6-8" is about a 16" dia speaker which sounds about right. Keep us posted as I'm facing the same kinds of problems with my NSB's. I hesitate to recommnd better 8" for the job as it usually hurts the pocket book. Zene
Previous Topic: Meet belle lab, a new manufacturer of single driver fullrange loudspeakers
Next Topic: D'Appilito array
Current Time: Thu Nov 19 10:36:57 CST 2026
