Home » Audio » Speaker » Damn Holes
Damn rear mounting speakers. [message #22680 is a reply to message #22673] Sat, 25 June 2005 23:38 Go to previous message
taylor is currently offline  taylor
I cut holes that also have a small gap. Im using silicon around each hole to fill the tiny voids. Then, I made the side panels extend out from the baffle to match the length of the round lip on the front of the driver. Next, I will take a strip of black foam, lay it between two thin sacrifical pieces of plywood, and use a 4" hole saw to cut holes. When done, this foam will slip over all the drivers' rings and be attached to the baffle and now flushs the rings with the side panels,baffle and completely disguises the ugly little frames, silicon and screws. Maybe the foam will even have some positive sonic effect.
taylor
Previous Topic: Component Values for ELF1.5 ?
Next Topic: I built a few open baffle speakers..........(lengthy and pointless)
Current Time: Tue Nov 03 20:44:27 CST 2026
