Home » Audio » Speaker » power tapering and l-pads
Re: power tapering and l-pads [message #22667 is a reply to message #22666] Mon, 20 June 2005 18:41 Go to previous message
Z,
Ths issue is that if you insert an L-pad in one or more of the woofer legs what you are doing is inserting more series resistance in the circuit. Effectively, you are changing the box tuning so you'll impact the bass extension of the woofers. If you do insert series resistance into the woofer leg, I would take another look at the box tuning impact before finalizing your design.
Jim
Previous Topic: Hay let's talk about planners and ribbon tweeters!!
Next Topic: Image perception
Current Time: Tue Nov 03 14:59:02 CST 2026
