Home » Audio » Speaker » K1840 for consultation
Re: K1840 for consultation [message #22607 is a reply to message #22603] Tue, 03 May 2005 10:20 Go to previous message
Anonymous
According to your design goals;
*Ken isn’t into high quality audio in any big way
*it plays loud (high SPL)
*it plays LOUD .... etc etc etc
*Therefore extreme high quality is not an issue here
The line array of those pioneer 4" midranges will do the trick.
Since there is no low pass crossover you should at least tame
the driver to make it sound good. A simple $5 modification will do
the trick. Coat the cone with 4 coats of lacquer.
To improve power handling there is another mod, but it cost $30-$40
and you have to inject about 5 - 10 tiny drops of ferrofluid on the
voice coil using a syringe. I've done alot of ferrofluid tests with the dust cap off and the only issue with no dust cap is -> the dust.
lol -- dust will clog the fluid and gum up the driver over a long
time. It's best to find a way to inject the fluid and keep the cap
on. The fluid boosts power handling alot, I drove 400 peak for about
10 minutes before the driver literally melted and fused the coil
stuck. The SPL was mad just from one driver, imagine the array. /hehe
If you don't use a high pass crossover there is a good chance
of destroying those drivers with excess bass. You shuold cross
them over ~100 - 200hz at least. To get good bass out of the design
you can port the midranges and tune it to 100hz to give you a nice
6 - 9db boost centered around 100hz.
I'm working on an array with those drivers and I have a diary
here;
http://www.caraudioforum.com/vbb3/showthread.php?t=210115
Essentially, the drivers will be modded with lacquer and phase plug
and maybe ferrofluid, unsure yet.
I uploaded some 'sneak peak' low quality pics and video here
of my current project I'm doing for a friend. http://www.caraudioforum.com/vbb3/showthread.php?t=216773
If you want to improve the sound alot, add a center horn {ie, compression driver w/lense}. Eminence would offer good results,
but PE has cheaper horns you can use. Here is a concept of a 3 way
line array with a center horn, those midranges, and some 7" woofers.
http://home.pacbell.net/lordpk/misc/Feandil-2.GIF
This design was built recently and the builder loved the sound,
he said it was awesome especially with that Eminence horn. He had
to lpad the horn. He powered his array using a QSC 2450 pro amp.
If you want more info on that project I can give you his email address
if you have specific questions. Send me an email to my hotmail.com
address, use thylantyr as the name.
Previous Topic: questions on Coral drivers
Next Topic: Acrylic transfer tape?
Current Time: Tue Nov 03 10:31:24 CST 2026
