Home » Audio » General » Sony DVP-S9000ES Video Off problem
Re: Sony DVP-S9000ES Video Off problem [message #226 is a reply to message #225] Mon, 16 February 2004 16:18 Go to previous messageGo to previous message
This may be overly simplistic, but are you sure the switch isn't stuck? I don't know if you're opposed to getting inside, but if you can measure the switch with a meter, see if pressing it gives continuity. If you don't have a meter, you might try jumpering across it for a quick and dirty check.
You might also want to check with Mark (footsurg) over on the Home Theater or Digital Video forums and see if he has anything to say about this problem.
Previous Topic: What'ja get your sweeties for Valentines Day?
Next Topic: 40hz horn ,new pic+jbl
Current Time: Fri Nov 13 09:25:30 CST 2026
