Home » Audio » Speaker » I need help in the creation of a midbass horn...
I need help in the creation of a midbass horn... [message #22596] Tue, 26 April 2005 00:41 Go to previous message
Matthew is currently offline  Matthew
Hi,
I need a little help figuring out how to make a midbass (50-300 hz or so) midbass/bass horn for my newest line array project
I was going to use 8 10" midbasses in just a normal line... but I believe better results (and cheaper) can be had with a bass horn...
I would like to try a 2 15" or 2 12" (preferably the former) per tower midbass horn... I'm unsure about the length and the area "inceasing rate" of a horn like this
I would like it to look like this diagram... but I'm unsure if this would work...
two major questions... will this setup be louder than 8 10's ported??
and is seperating these two horns and having one side perfectly horizontal, will it work like I drew?
Previous Topic: Checking with meter
Next Topic: Bastanis Prometheus vs PHY - anyone heard them?
Current Time: Fri Nov 06 00:15:33 CST 2026
