Home » Audio » Speaker » My finished line array *pics*
My finished line array *pics* [message #22584] Wed, 13 April 2005 20:42
Matthew is currently offline  Matthew
well after much much help from thy and a lot of reading here's my expensive FINISHED like arrays...
http://www.sounddomain.com/memberpage/424669/4
each tower contains:
20 NSB's painted and modded with lacquer- HP'd at 400 hz, LP'd at 2.5khz@18db
8 7" Dayton Aluminum midbasses, in 2.5 cubes with polyfill, tuned to 34 hz, LP'd at 400 hz
1 Eminence Horn, with 14x7" lense, HP'd at 2.5khz@ 18db
each tower has custom passive crossovers with a power handling of 1400 watts PER TOWER!!!
I'm powering them with a QSC 2450... which gives each tower 1200 watts RMS
final impedence per tower (if not bi-amped or tri-amped) is 1.98 ohms
The camera made the paint look spotted but it really is quite unifrom and reflective
And the grills are flush with the horn area making the profile FLAT! very sexy in person
also they are only 6" deep at the top!
Previous Topic: tube amps and vibrations
Next Topic: Gumby Lives !!!!!
Current Time: Fri Nov 06 05:22:22 CST 2026
