Home » Audio » Speaker » Car components for home line array
Re: Car components for home line array [message #22579 is a reply to message #22576] Mon, 04 April 2005 22:12 Go to previous message
Dave Peterschmidt is currently offline  Dave Peterschmidt
JP,
I don't believe that'd work very well. For one thing, your tweets wouldn't be close enough together, causing some comb filtering effects. Depending on where the crossovers are set, you might also have that problem with the mids. I would think you'd be better off buying speakers designed for home use and creating an array with them rather than trying to shoehorn car speakers into a usage they weren't designed for.
Previous Topic: Altec 515B
Next Topic: Schematics for JanZens?
Current Time: Fri Nov 13 14:12:55 CST 2026
