Home » Audio » Speaker » macintosh xrt 29
Re: MacIntosh XRT 29 Comments [message #22574 is a reply to message #22572] Sun, 03 April 2005 19:54 Go to previous messageGo to previous message
jdybnis is currently offline  jdybnis
Jim said:
You need to be shooting for a crossover in the low 2000's Hz(possible) or sub 2000 which the PT2 can not do. I have used the PT2 type planar as low as 2300 Hz (third order).
cmanning,
The higher the order of the filter is the lower you'll be able to cross. If Jim used a 3rd order at 2300Hz. You could certainly drop it to 2000Hz with a 4th order slope. Probably even lower if you wanted too.
Previous Topic: Confused about amp output, sensitivity and speaker SPL
Next Topic: Altec 515B
Current Time: Thu Sep 24 15:32:34 CDT 2026
