Home » Audio » Speaker » Power Tapering
Re: Power Tapering [message #22565 is a reply to message #22564] Tue, 29 March 2005 13:08 Go to previous messageGo to previous message
Paul L. is currently offline  Paul L.
Thank you Jim. I think you explained what I needed to know even if I wasn't as clear as I could have been.
I was thinking that the middle two drivers needed to be wired in such a way as to present a load half of what the outer six drivers would present, then the other two drivers(4&7) would split the difference. So lets say that drivers 1,2,3,8,9,10 gave an 8ohm load, drivers 4,7 a 6ohm load, and drivers 5,6 a 4ohm load. This to me was a taper, and I was looking for three levels. It seems there are only two power levels in a 3/2/2/3 taper.
If I understand you correctly, drivers 1,2,3,8,9,10 will give the same load(2 sets of 12ohms each), and drivers 4,5,6,7 will also give the same load(2 sets of 8ohms each). When these are wired in parallel, there wil be a total load of 2.40 ohms. Correct?
Thank you again for your help.
Previous Topic: soundstage loud speakers
Next Topic: So, what do I do with these now?
Current Time: Fri Nov 13 09:32:55 CST 2026
