Home » Audio » Speaker » horizontal line array for center.
Re: horizontal line array for center. [message #22554 is a reply to message #22553] Wed, 23 March 2005 19:43 Go to previous messageGo to previous message
justinc is currently offline  justinc
Jim,
Thanks alot for the advice on this project. I think I'm going to go ahead and give it a try. How do you feel about the jp2 as compared to the jp3, it has a higher sensitivity therefore would be easier to pad down, instead of padding down the woofer. I have heard though that its vertical and horizontal dispersion is not near as good as that of the jp3. Thanks for the help
Justin
Previous Topic: Repeated JVC Question
Next Topic: soundstage loud speakers
Current Time: Thu Sep 24 20:14:33 CDT 2026
