Home » Audio » Speaker » Open baffle array wings
Re: Open baffle array wings [message #22551 is a reply to message #22545] Wed, 23 March 2005 00:57 Go to previous message
Zene Gillette is currently offline  Zene Gillette
Spend a little time with the Edge program. http://www.tolvan.com/edge/ Look at the response curve of your design and see how much eq (that is BOOST ... read, phase shifting, distortion) you need to get the lower cutoff frequency you want. Hint: Try a tapered design, wide at bottom and very narrow at top. Still has "small" look.
BTW, eq is not the answer to audio reproduction. Some cut and damn little boost should be the limit. Zene
Previous Topic: bd's design
Next Topic: As a prem to answer the question of cancelled waves.
Current Time: Wed Nov 04 03:36:55 CST 2026
