Home » Audio » Speaker » Finished a new array
Re: Finished a new array [message #22456 is a reply to message #22455] Mon, 31 January 2005 10:22 Go to previous messageGo to previous message
Allan is currently offline  Allan
thylantyr,
"Got any tips for integrating the NSB to PT2?
They seem to integrate themselves pretty well. As I mentioned before, it's helpful to have some way of boosting/attenuating the individual lines in the array. If you really wanted to go whole hawg, having some EQ available to flatten the HF rolloff above 10khz would be pretty cool.
"crossover you use?"
I'm using an active 3-way XO (Ashly XR2001). If I remember right, I think I had the XO at 150hz and 3.5khz in the end for the NSBs, but it seemed to work well with a pretty large deviation from those points too. Probably a taste thing.
"sealed vs. open baffle sound ?"
I don't have room to get speakers away from walls in here, so my dipole experiments have been less than successful. I built the NSB arrays as OBs initially, but ended up closing off the backs. Alot of people with the room to do it in, have had good success running them as dipoles however, so that'd be up to you and whether or not you can take adavantage of it.
These new arrays are sealed. I went for a standard Qtc of .7 with some fiberglass to soak up reflections back thru the cones. I won't be doing anymore dipole speakers in here except for quick listens to hear the drivers.
Previous Topic: I would like opinions on NewForm 645R V2 please
Next Topic: Tangband Array & Home theater
Current Time: Sat Oct 31 20:38:45 CDT 2026
