Home » Audio » Speaker » Power tapering Idea - Mass loading ?
Re: Power tapering Idea - Mass loading ? [message #22430 is a reply to message #22429] Fri, 14 January 2005 08:20 Go to previous messageGo to previous message
Hi Jorge
I think you are referring to adding extra mass to the cone? You're 100% right - adding extra mass will lower Fs, lower sensitivity and will also raise Qms and hence Qts. It will reduce excursion-limited power handling though, if your intent is to use it at lower frequencies, which is what I think you want to do as you wouldn't add extra mass unless you wanted it to do deeper.
Adrian
Previous Topic: E130-8 horn load or 2 on open baffle or K-Horn?
Next Topic: heard a new prototype
Current Time: Sun Nov 01 12:21:28 CST 2026
